Help!! Unix/mac problem
sjean
4 MB
Post by sjean » June 19th, 2011, 9:32 am
How do I open a unix file from disc on a mac iv tried reading about it but I don't understand. Any help! I would be very greatfull :)
24bit
Re: Help!! Unix/mac problem
Post by 24bit » June 19th, 2011, 12:20 pm
Hi,
could you be a bit more precise, please? What kind of files on which media do you want to move between which computers?
What did you try so far?
Best wishes!
sjean
4 MB
Post by sjean » June 19th, 2011, 1:00 pm
There are some movies and pictures on a disc that r classed as unix expendable file's all I can do is click quick look but that won't show anything either I just want to know how to open them up or change format so they can be opened up. Thanks :)
24bit
Post by 24bit » June 19th, 2011, 1:13 pm
Are those very big or confidential files?
If not, could you upload to Mediafire to let me take a look?
I have a GNU-Linux box and might try to inflate the files, if you wish.
You might also try the Unarchiver, which usually can inflate tar/gz files and a lot more.
http://wakaba.c3.cx/s/apps/unarchiver
sjean
4 MB
Post by sjean » June 19th, 2011, 2:02 pm
To be honest I couldn't tell u wants on them at the moment that why I want to unlock/open them lol
Post by Turboladdade » June 19th, 2011, 2:23 pm
Well "files" aren't necessarily Unix-specific. Do they have a file extension? Do you know what program created them? What are they named? Are they executables (applications) or documents (created by an application)?
You can open any file with TextWrangler and it will show you its raw contents. You could possibly determine the nature of the files that way.
sjean
4 MB
Post by sjean » June 19th, 2011, 3:04 pm
I didn't create the files all I know is there from another mac and they are pictures and movies
24bit
Post by 24bit » June 19th, 2011, 5:00 pm
At least you know them to be Mac files :-)
As Snow Leo ignores FILE and CREATOR types you have to guess I´m afraid, unless you try what Turboladdade suggested.
Classic has some apps that will show the ID´s, you could try to check the files there.
Can you open some files with Miro maybe? Miro has quite a lot of movie converters built in.
leonAzul
Post by leonAzul » June 26th, 2011, 11:55 am
If you know them to have been created by another Mac, there is a very good chance you can open them in QuickTime Player with the "File>Open File…" command.
The freeware VLC also opens a wide variety of media formats natively not supported by QTP without extra plug-ins.
