APC Tracker 1.0 - APCUPSd client for MacOS
Post by Info-Mac » August 21st, 2001, 9:00 am
Download: http://archive.info-mac.org/cfg/apc-tracker-10.hqx
I have uploade the file APC Tracker 1.0.sit.hqx to the FTP server.
Description:
The equinux APC Tracker is a APCUPS compatible client application, that
powers off a Macintosh client computer regularly once power is
interrupted. When starting up, the application connects to a APCUPS
network server (mostly under Linux/Windows), that is directly connected
to the UPS. The server sends a signal to the client in case of a power
failure. This is a fully-functional demo until you register.
Requirements: Mac OS 8.5 or higher or Mac OS X 10.0 or higher
Webpage: http://www.apctracker.com
Email: apctracker@equinux.com
