Switch-It 3.1 - Switch Applications via the Keyboard - *Freeware*
Post by Info-Mac » July 5th, 2000, 9:00 am
Download: http://archive.info-mac.org/cfg/switch-it-31.hqx
Switch-It is *yet another* keyboard-based application switcher. It is
user-friendly, fast, responsive, reliable, simple yet powerful... ^_^
Requires Mac OS System 7.0 or later (System 7.5 or newer is recommended).
Compatible with Mac OS 8.5 and later.
"What's New since Version 3.0"
* Added more extra keys:
- Switch to the next application (standard and auto-hide) in launch order.
- Switch to the next application (standard and auto-hide) in alphabetical
order.
- Switch to the next application (standard and auto-hide) in front to back
order.
* Simplified the user interface: the Quit and Show/Hide features are now
always enabled.
* Added a menu command in the control panel, to turn on and off the Mac OS
8.5 built-in Application Switcher (previously a stand-alone application
called "Toggle Application Switcher").
* Included an "unpolished" Japanese version.
Mikaeru Software:
--Michel MARIANI (a.k.a. Mikaeru)
