The Dailies 1.0.6 - Daily Startup and Shutdown Items.
Post by Info-Mac » April 19th, 2001, 9:00 am
Download: http://archive.info-mac.org/cfg/the-dailies-106.hqx
"The Dailies" create the possibility of having Startup Items and
Shutdown Items that are launched only once every day - no matter how
often you may need to restart.
Use:
Throw the "Daily Startup" application in your "Startup Items" folder.
The first time it's run it will create a "Daily Startup Items" folder
in your System Folder. Whatever you put in that folder will be launched
no more than once a day.
Throw the "Daily Shutdown" application in your "Shutdown Items" folder.
The first time it's run it will create a "Daily Shutdown Items" folder
System Requirements:
- AppleScript needs to be installed
- Works under Mac OS 7.5 through 9.1
History:
- 1.0.6 Fixed a bug where sometimes DailyStartup would stupidly inform
you that the folder "Daily Startup Items" already exists.
- 1.0.5 - Now also works correctly under non-US systems (more
specifically: if your Date & Time settings are non-US).
- 1.0.4 - First public release
Legalese:
The Dailies are freeware. Do with it whatever you like, except sell it!
