ChooserUser 1.3.1
ChooserUser 1.3.1
Post by Info-Mac » March 12th, 1997, 11:00 am
Download: http://archive.info-mac.org/disk/chooser-user-131.hqx
ChooserUser 1.3.1 is a freeware control panel that lets you control who can
change the owner name (or user name under System 6). It also allows the owner
name to be changed at startup, either manually or automatically. This program
will be particularly useful to public Macintosh labs found in university
settings.
ChooserUser 1.3.1 fixes a bug in ChooserUser 1.3: When set to prevent a user from
bypassing the AppleShare logon dialog, ChooserUser disables escape key. This key
was being disabled in other places inadvertantly, and this is now fixed.
Web surfers, check out the Flux Software web page at http://www.fluxsoft.com/.
-- Maurice Volaski, Flux Software support@fluxsoft.com
http://www.fluxsoft.com/ ftp://ftp.fluxsoft.com
