Disk configuration and file management utilities and info. RAM disk, image mount, disk analysis & repair, scsi management, disk copying, file cataloging, directory search, file concatenation, file save & recovery, file comparison & update, alias & trash management. Folder locking, file shredding. (For compression and encryption utilities, see
Compress-Translate. For utilities that work only on text files, see
Text.)
- Administrator
DupFinder 1.2.1
Post
by Info-Mac » October 9th, 2001, 9:00 am
Download:
http://archive.info-mac.org/disk/dup-finder-121.hqx
DupFinder can quickly and easily remove duplicate files from your hard disk
by replacing the duplicates with an alias of a "master" file. Eliminates
disk clutter as well as saving disk space. DupFinder is a Carbon
application, so it works with OS 8, 9, & X.
Maui Software
