Download: http://archive.info-mac.org/disk/haxial ... log-12.hqx
Haxial DiskCatalog is a fast utility for cataloging CDs, hard disks,
folders, and any other type of disk. It allows you to browse the
contents of disks without having to find them and insert them into your
computer. More importantly, you can search all of your disks at once
(again without having them in the computer), and DiskCatalog will display
a list of all the files found, and their location. When you're looking
for a file and you don't know where it is, this is much easier than
manually searching all your disks. DiskCatalog is designed to be very
fast -- search results usually appear instantly.
DiskCatalog is available for:
MacOS 9 or better (with CarbonLib 1.3.1+).
MacOS X (10).
Windows 95 or better.
The Product Page is here:
http://www.haxial.com/products/diskcatalog/
And the company website is:
