List Launcher
List Launcher
Post by Info-Mac » April 24th, 1997, 9:00 am
Download: http://archive.info-mac.org/disk/list-launcher-ppc.hqx
List Launcher (version 2b10)
List Launcher is a utility that is designed for quick, simple and logical access
to commonly used folders, files, applications, desk accessories or any other type
of file. It also provides a utility for quickly moving between different open
applications.
List Launcher is an application. This means that in order to use List Launcher
you need to make it the active application. List Launcher provides several
convenient methods for accessing and launching files.
Freeware.
