Download: http://archive.info-mac.org/disk/rambunctious-15.hqx
What is new in ramBunctious 1.5?
- ramBunctious is now even faster.
- New color "LED" indicators showing disk accesses.
- Improved periodic-save intervals.
What is ramBunctious?
ramBunctious 1.5 is a shareware ($25) RAM disk program for the Mac OS.
Its rich set of features lets you customize your RAM disks for your
desired balance of speed, security, safety, and versatility.
- You can have several RAM disks mounted simultaneously, limited only
by memory available.
- ramBunctious has a "write-through" option. When activated, everything
written to the RAM disk is saved to a (real) file. This means that
the next time you mount the RAM disk, all the contents are still
there. This helps protect against data loss in the event of a crash
or power failure.
- ramBunctious uses normal application memory. This means that when
you're done using a RAM disk, that memory is available for other
applications to use. In other words, you don't have to reboot to
reclaim the memory.
- Each RAM disk may be configured to be mounted automatically during
the computer's startup process.
- These options, and more, are fully user-configurable for each RAM
disk via a status/settings window. In addition to the settings, the
status window includes LED-like access indicators that flash when the
RAM disk is being read from or written to.
- ramBunctious is fully AppleScriptable.
ramBunctious 1.5 is available now. More information is available at the
ramBunctious web site:
http://www.clarkwoodsoftware.com/rambunctious/
Inquiries, comments, and questions may be directed to:
rambunctious@clarkwoodsoftware.com
ramBunctious 1.5 copyright (c) 1995 - 2000 by Clarkwood Software
