Download: http://archive.info-mac.org/disk/rearra ... 121-jp.hqx
This is the Japanese version of the Rearrange Folders package.
Rearrange Folders is a program which lets you optimize the positioning
of windows of disks and folders in the Finder. You can specify where the
window for a disk or folder should open and Rearrange Folders takes care
that any folder inside that folder will open neatly stacked on top of
the first folder so that your screen does not get so cluttered.
Additionally, you can specify how the items in the windows should be
ordered and you can choose whether to display the contents as icons,
buttons or list view. Ê Ê
Examples of uses for Rearrange Folders
Normal users:
Clean up the window positions on your screen. Make it
easier to navigate through multiple levels of folders because you can
have windows stacked in such a way that you can always see parts of any
window. You do not need to close windows again only to be able to see
other windows which get buried under other windows!
CD-ROM authoring, Programmers, Shareware authors:
Before burning a CD-ROM you can determine where the various windows
for folders on the CD will open on the screen. Your CD will look more
professional when the windows do not appear in random locations.
You can also ensure that the windows are always visible even when the
users of your CDs are having smaller screens than you have. Ê
System requirements for Rearrange Folders:
Rearrange Folders should run
on all Apple Power Macintosh and PowerBook computers with a PowerPC
processor and Mac OS 9. The Finder has to be running for Rearrange
Folders to function. While Rearrange Folders may also run with earlier
version of MacOS, we do not guarantee nor do we support such
configurations.
