Download: http://archive.info-mac.org/edu/max-pia ... er-321.hqx
MaxPianoReader 3.2.1 is sight reading software for the Macintosh. By
practicing with MaxReader you will learn to read music and in
particular you will learn the skill of "looking ahead" while reading
music. This sight reading software continually presents you with new
music in a two bar, two staff window. To keep up with the presentation
you must
learn to memorize the last few beats of music and then play that from
memory WHEN the screen redraws. In this way you will learn to "LOOK
AHEAD" in the music. THIS is the critical skill that will make all the
difference to your sight reading ability. Once you get a flow going, you
can increase the tempo. You will never be able to "cheat " with
MaxReader. You can't stop to fix up your mistakes, nor can you
"memorize" the music. In a very short time you will be reading with a
confidence you never dreamed possible. The skill you learn by using
MaxReader easily transfers itself to a written page of music.
THE ADVANCED MUSIC FILES will let you MASTER UNFAMILIAR STYLES be it
Jazz, Latin, Classical or 12 tone music. The sky's the limit with this
new and educationally effective sight reading software product.
This demo is fully functional for 60 seconds. Purchasers of the program
receive a version authorized
for their particular machine AND new music files at regular intervals.
System Requirements:
Minimal - System 7.6.1, any old mac SE30 or better, 4MB of ram,
QuickTime musical instruments installed.
Company URL
http://www.education4music.com
Price:
US39.95
