Download: http://archive.info-mac.org/info/sft/ap ... events.hqx
Enclosed find a word document that has information
about a bunch of applications that support Apple Events.
I found it on AppleLink. I don't remember seeing it submitted...
Apgar@Apple.com I said it, NOT Apple.
MOVED OVER PR NEWSWIRE AT 8:16 AM, EDT MONDAY, DECEMBER 13, 1993.
Contact:
Emilio Robles
Apple Computer, Inc.
(408) 862-5671
or
Toni Giusti
Cunningham Communication, Inc.
(408) 982-0400
Apple Delivers New AppleScript Scripter's Kit for Solution Providers
Thanks to everyone who responded. As you'll see from the attached
mail, there was some skepticism about disk-level auto-compression,
though one person was using Stacker without any problems. One person
suggested a new disk drive, which I am too cheap to buy at the moment.
I went ahead, installed Stacker and got rid of Autodoubler. This
eliminated the mysterious spinup problem, *and* gained me disk space,
since Autodoubler was not compressing my System Folder. So far so
good. Here come the messages:
Original posting:
I am about to go this route, and was wondering if any have travelled
it before me. I am about to dump Autodoubler (2.0.3), which is spinning my
Powerbook drive up every thirty seconds, and which is incompatible
with Quicken 4.0 and macBible 3.0. I'm running Stacker on my HP 95,
and it just seems to work. I want to try it on my PB 100 8/40, and
AWOL Utilities 1.4: Where to Find Them!
April 24, 1998
Internet mail address:
ab026@freenet.carleton.ca
Paper mail address:
AWOL Software Productions
PO Box 24207
Hazeldean RPO
Kanata, Ontario, Canada
K2M 2C3
Package contents:
Each program archive includes the "About AWOL Utilities" file, which gives a
capsule summary of all AWOL Utilities programs.
Virtual Desktop 1.9.2: powerful virtual desktop manager for all Macs and monitors
Maybe 1.5.3: Finder alias enhancer, useful with Virtual Desktop
Help on Wheels 1.3: stand-alone help server, used with all AWOL Utilities
HoW Developer's Kit 1.3: developer's kit for Help on Wheels client applications
When I recently had a PageMaker 5.0 file go belly-up on me because of a
"'Bad Record Index'" error, I collected many tips on dealing with this
ominous problem which I thought I would share. I am sending you a
detailed set of instructions which may be of use to others for placing
in the archives.
Dealing with "Bad Record Index" errors in PageMaker.
The main points are these:
Prevention:
1. Update to PM 5.0a (but do turn off ALL inits first; the installer is
a killer otherwise).
2. In Preferences, make sure "Save smaller" is checked.
