Download: http://archive.info-mac.org/inet/download-wizard.hqx
DownloadWizard 1.0
What it is: AppleScript droplet that downloads files which are listed as
URLs in a text file.
Author: Ton Brand
Company: Ton's Software
License: Freeware
Computer: PowerPC or iMac
Mac OS: Mac OS 8.6 or later
Abstract:
DownloadWizard is an AppleScript droplet that downloads files which are
listed as return-delimited URLs in a text file. The default download path is
the root of your startup disk, but you can define a destination folder. You
can also choose to have Remote Access disconnect you when all downloading is
done - by default you will stay online.
Your starting point is one or more text files that contain downloadable
URLs, separated by hard returns. The following protocols are supported:
http, https, ftp and file. If the program sees a wrong URL, an alert is
displayed suggesting to skip this URL. For your convenience, this alert will
abort itself after 20 seconds, so that the whole process can continue, which
is important if you let the program download a bunch of files overnight.
To start downloading you simply drag the text file(s) that contain the URLs
to DownloadWizard's icon.
