Download: http://archive.info-mac.org/inet/jons-r ... 10-68k.hqx
Jon's Remote Control allows you to access your computer from the Internet or
a terminal emulator. You can specify up to five passwords, then select
TCP/IP or Terminal mode. Once up, you can connect to your computer from
anywhere on the Internet and manipulate files with MS-DOS-type commands.
Supports Telnet, Chargen, QotD, FTP, Time Server, Private Terminal Access,
Finger, Private Terminal Link, and Remote Telnet protocols.
