Download: http://archive.info-mac.org/inet/conn/d ... ros-kq.hqx
The Download Macros are a set of macros that makes downloading multiple
files from the Internet easy. Specifically, it is a KeyQuencer macro
that allows for downloading files in Netscape without the hassle of
being at your computer. The macro is small and simple yet can be a
great convenience to you. This is not something you want to skip over,
and at only a few k, it takes seconds to download.
Requires:
Netscape 2.0 or greater
KeyQuencer 1.x or 2.0
Jared Mellin
(Jar-Head)
JMellin@pinecrest.edu
