Download: http://archive.info-mac.org/inet/web/ul ... s-2001.hqx
Thank you for downloading the SHAREWARE list of the " UltraMacBookmarks' Now
you too can be a MacHead without the mess and fuss of visiting all those
sites to bookmark them. The file will work with both Int ernet Explorer and
Netscape1s Communicator 4.5x up. Although not tested the bookmarks should
work with all versions 4.0..x and up. Let me know when you try them.
This update has several NEW folders for quick surfing without opening the
larger MacHead's set. Many new listings.
$12 SHAREWARE 1500+ Bookmarks Apple oriented.
NEW!! NEW!!!
Included with this download are some Alert Sounds for your pleasure. these
can be put into your close system folder (instructions included) and then
activated for use in your regular Apple Alert Sounds or better yet use in
your Browser. They include such sayings as You've Got Mail, and Goodbye
and other such familiar ones. There is no charge for these recordings. I
know you'll enjoy them.
