Download: http://archive.info-mac.org/inet/web/cgi/procon-10.hqx
PROcess CONtrol
ProCon is a simple cgi that gives you web-based control of the processes
(applications) running on your server.
Server Requirements:
1) The scriptable Finder, which is included in System 7.5 and later,
and is available for some earlier systems. 2) Parse CGI OSAX,
shareware which is available at
. This must be
installed in the Scripting Additions folder (in the Extensions folder).
3) WebSTAR, Quid Pro Quo, or other webserver that follows the WebSTAR
cgi standard.
The browser used must support tables.
For more information, please read the ReadMe.
Chris Buxton
