Download: http://archive.info-mac.org/inet/web/nt ... ive-as.hqx
This AppleScript is for people who are addicted to MIT's Info-Mac
HyperArchive, but want to download files from a different (closer)
Info-Mac Mirror.
Stick it in your Apple Menu and when you find something in the
HyperArchive that you want, copy the URL to the clipboard, then run the
script. The first time the script runs, configure it with the mirror of
your choice. Follow the example.The script then makes Netscape get the
file you have selected from the mirror specified. If you want to change
the mirror, recompile the script with Script Editor and run again.
I could have used the InternetConfig Info-Mac Mirror preferences instead
of having to enter the mirror by hand, but I didn't get around to it.
Joe
Joe's Virtual Macintosh --> http://www.sn.no/~cvoss/Joe
