Download: http://archive.info-mac.org/inet/web/nt ... engine.hqx
I created these search engine thingeys because of my dislike over search
engines interfaces...
I just wanted to type the stuff in and get results, no drop-down menus
or anything like that, just type and go! So here they are, plan and simple
applescript applets. You need Netscape and applescript (of course).
This is "home page ware" (much better than eucalyptus vapor ware!) you
have to visit my home page and I'll let you download the "registered"
version. The only differences are:
* You can edit the apple script.
* Every time you use it, it won't open my page also.
The "registered" version is at http://www.tssphoto.com/search/,
My actual home page is at http://www.xmission.com/~tedebair/
or http://brapp.xmission.com/ (my 660AV's web server), but I'm going to be
leaving for Chile until July '98 and I doubt my provider will just let me
keep the pages.
I would like to thank The Stock Solution for giving my pages a home.
Chris Bair
tedebair@xmission.com http://www.xmission.com/~tedebair/
