Download: http://archive.info-mac.org/sci/igor-pr ... -files.hqx
IGOR Pro 3.01 is an interactive environment for experimentation with
scientific and engineering data and for the production of
publication-quality graphs and page layouts.
The IGOR Pro 3.01 Demo is divided into parts for downloading.
Normally you will need only one of the three application files.
We strongly recommend you also download the help file (IgorHelpFilesDemo.sit.hqx)
AND the examples file (IgorExamplesDemo.sit.hqx):
IgorProFPUDemo.sit.hqx
Application for 680x0 Macs with Floating Point Units.
IgorProNoFPUDemo.sit.hqx
Application for 680x0 Macs without Floating Point Units.
IgorPowerMacDemo.sit.hqx
Application for Power Macs (IGOR Pro is a "native" application),
and system extensions for the Power Mac.
Help and other support files. You need this.
Demo files that show you why IGOR Pro is cool.
You need this, too.
IgorTechnotesDemo.sit.hqx
Technical notes are Word 5 files and IGOR experiments explaining
how to use IGOR to accomplish common tasks. Included are technotes
about statistics x-test, digital signal processing, peak measurement
and fitting, ternary graphs, complex arithmetic, and a batch file
demonstration experiment. We have more than are included in this
archive; others can be retrieved from our FTP sites.
After downloading, uncompress the files with something like
Stuffit 3.0, or StuffIt Expander. You will then have one folder
named "Igor Pro Folder", and other folders named something like
"1 PutContentsIn Igor Pro Folder", "2 PutContentsIn Igor Pro Folder", etc.
Copy the CONTENTS of the folders named "1 PutContentsIn Igor Pro Folder",
"2 PutContentsIn Igor Pro Folder", etc, into "Igor Pro Folder".
Trash the now-empty folders.
IGOR Pro is a product of WaveMetrics, Inc.
Email: sales@wavemetrics.com
support@wavemetrics.com
WWW site: http://www.wavemetrics.com/
Voice: (503)-620-3001
FAX: (503)-620-6754
