Download: http://archive.info-mac.org/text/findtext-135.hqx
FindText 1.3.5
FindText is a utility that can search the files on your harddisk for that
specific text you know is hiding somewhere. Simply type in the text, tell
it what folder(s) or disk(s) to search, and it will find all files
containing that text. This saves you having to open ten or more files to
get hold of the one you're after, and FindText can work in the background,
which means you can get on with something else rather than watching the
progress bar crawl across the screen. If speed is important, try FindText.
FindText can search the data- and/or resource-fork of your files.
FindText needs System 7 or better and runs native both on the PowerMac and
the 68020/030/040 Macs. FindText is fully compatible with Mac OS 8.
Version 1.3.5 is a minor update.
FindText is shareware (USD 20). You can also register via Kagi (creditcard,
cash, check, ...).
Best regards,
Patrick Maes
maes@kagi.com
