Download: http://archive.info-mac.org/gui/pop-char-pro-133.hqx
This is PopChar Pro version 1.3.3.
PopChar Pro extends your menu bar with a menu that shows all characters
available in the current font. Select a character from that menu to "type"
it into the currently edited text.
Version 1.3.3 is a maintenance release with the following changes:
Problems Fixed:
* Opening the PopChar Pro menu under Mac OS 9.2 (and 9.2.1) sometimes
caused a crash.
* When a font file was open in the Finder, PopChar Pro didn't show
that font.
Improvements:
* Display of the PopChar Pro menu has been accelerated.
PopChar Pro is distributed by UNI SOFTWARE PLUS. This submission contains
the PopChar Pro Installer that will ask for a license key. If you don't have
a license key, the installer will create a full-featured but time-limited
demo.
UNI SOFTWARE PLUS GMBH
Softwarepark Hagenberg Tel: +43 7236 3338-82
A-4232 Hagenberg, Austria Fax: +43 7236 3338-30
Sales: mailto:popchar-sales@unisoftwareplus.com
Support: mailto:popchar-support@unisoftwareplus.com
WWW: http://www.unisoftwareplus.com/products/popchar.html
