Videowall
Matthijs
Videowall
Post by Matthijs » June 14th, 2011, 4:11 am
Hello,
I'm having a little problem with arraysync.
I want to make a videowall out of 4 Mac's and all I can do now is play the same video on every mac.
How do I make every mac show a piece of the same video?
If this works, I'm buying :)
Re: Videowall
Post by Turboladdade » June 14th, 2011, 8:56 am
If your on Mac OS X, put ArraySync into Spanned mode, enable Offset, and then Set the offset to the dimension of the other displays on each computer. So if you're doing a 2x2 grid, you'd configure ArraySync on the upper left quadrant to have a right offset and bottom offset equal to the width and height of the remaining column and row of displays.
Unfortunately this isn't available for WIndows users.
Matthijs
Re: Videowall
Post by Matthijs » June 14th, 2011, 10:04 am
@Turboladdade Thank you for this information.
So I have to do this on every client computer in order to make the video wall. Do I have to do anything with the server computer?
Re: Videowall
Post by Turboladdade » June 14th, 2011, 10:21 am
If the server is part of this matrix then yes you'd repeat this process on all machines including the server.
