iMac Screen Dimness
helloimjoe
iMac Screen Dimness
Post by helloimjoe » December 5th, 2007, 11:08 pm
Hi! On my white intel imac, the screen dims after a minute or two of not being used, which is annoying when reading or watching a video. When I set the control for that not to happen it still does... Any ideas?
Muahahahahha!
mrkramer
Re: iMac Screen Dimness
Post by mrkramer » December 19th, 2007, 11:29 pm
check in system preferences under energy saver, that is the only place that I know of that will control when the screen goes off.
Post by Turboladdade » December 19th, 2007, 11:30 pm
I've heard of this before and I think I recall a permission repair did the trick.
You can also try creating a new user account, logging in, and see if the same symptoms occur. This way you can pinpoint it as a problem specific to your account (and settings, or possible corruption thereof) or a global problem.
helloimjoe
Post by helloimjoe » January 1st, 2008, 12:54 pm
It seems that upgrading to Leopard did the trick, it works fine now... weird that Apple never addressed it with Tiger.
Muahahahahha!
macuser77
Post by macuser77 » January 1st, 2008, 1:52 pm
Did it dim while the computer wasn't being used, then a keystroke or mouse movement brighten it back up, or did it just stay dim?
Proud Mac User since 1999.
Friends don't let Friends use Windows.
helloimjoe
Post by helloimjoe » January 2nd, 2008, 11:07 pm
It would brighten back up after moving the mouse, taping the keyboard and such, but I didn't want it to go dim because it was annoying when reading articles and watching youtube videos... but when I turned off the setting to make it do that it still would.
Muahahahahha!
