low usb power in cube
madmann
Post by madmann » December 27th, 2007, 8:41 pm
I just got an error trying to attach an ipod nano to a cube. Will a powered usb hub fix this issue? any other solutions?
Re: low usb power in cube
Post by Turboladdade » December 27th, 2007, 9:22 pm
You got a low power warning plugging the iPod directly to the cube? That shouldn't happen I don't think, although I know that message will appear if you plug an iPod into the keyboard rather than computer itself.
madmann
Post by madmann » December 27th, 2007, 10:37 pm
you are correct i did plug it into the keyboard. with only 2 usb ports directly in the cube. one for keyboard other for speakers what would you do? i used my keyboard port on the quicksilver no problem.
Post by Turboladdade » December 27th, 2007, 10:43 pm
Apple Keyboards are not designed to provide USB power. I would say you should definitely get a hub, or get non-USB speakers. Make sure you plug the hub into the computer and not the keyboard.
madmann
Post by madmann » December 27th, 2007, 10:46 pm
usb speakers are the only option with a cube.
i have to have a powered hub correct just a std hub would not help
Post by Turboladdade » December 27th, 2007, 11:19 pm
madmann wrote:usb speakers are the only option with a cube.
Ah, this I did not know. Your best bet is to look for a powered hub, then.
