adding internal SATA Hard drives to PowerMac g4
josearturo
4 MB
Post by josearturo » October 23rd, 2008, 10:58 pm
I'm considering adding two sata internal drives to my g4. Can some advise if the following equipment is compatible with the g4?
1 Tempo PCI SATA card $80
http://www.sonnettech.com/product/tempo_serial_ata.html
2 Western Digital Caviar SE16 500GB Hard Drive
7200, 16MB, SATA-300, OEM $140
http://www.tigerdirect.com/applications ... ywgfCjCmH4
arturo
Re: adding internal SATA Hard drives to PowerMac g4
Post by Turboladdade » October 23rd, 2008, 11:36 pm
The Sonnet cards are specifically designed for use with your Mac and will work fine. The drives them selves are all interchangeable; it doesn't matter if you have a drive from WD or Seagate or Hitachi, they all connect to and operate the same. So I'd say go for it.
josearturo
4 MB
Post by josearturo » October 28th, 2008, 11:45 pm
OK. Thanks. I'm going for it.
kriegvision
Post by kriegvision » October 29th, 2008, 11:49 pm
Let us know how that works out. I vaguely remember reading somewhere (maybe here) that someone had done it and despite what Sonnet's website says, it was giving them trouble. I doubt that is the case for most people, but would still like some reassurance.
Post by Turboladdade » October 29th, 2008, 11:53 pm
kriegvision wrote:I vaguely remember reading somewhere (maybe here) that someone had done it and despite what Sonnet's website says, it was giving them trouble.
Perhaps in this thread?
Installing More Than 128 GB Internal Hard Drive in a G4
phil connors
Post by phil connors » January 13th, 2009, 1:20 am
josearturo wrote:OK. Thanks. I'm going for it.
Did you have any problems?
current
Post by current » May 4th, 2010, 4:39 am
Does anyone have a brand or model of preference in terms of selecting a SATA internal hard drive?
An internal hard drive can be purchased for use with different interfaces, including SATA ports.
sxbaan
Post by sxbaan » May 4th, 2010, 9:51 am
I seem to have a bias toward Seagate hard drives. I've been buying them for as long as I can remember now.
