Buying guide
Prince Kiss
Buying guide
Post by Prince Kiss » December 13th, 2012, 1:20 pm
Hi peeps, I am trying to move from windows to mac. In a dilemma which to get. The high specs MBA or the new rMBP. It will be mainly for studies, music,movies, games now and again and design.
Re: Buying guide
Post by Turboladdade » December 14th, 2012, 7:36 am
The MacBook Pro with Retina display is the bleeding edge of technology. However there is one drawback that its ultrafast solid state storage is lower capacity then the traditional platter-based storage of the regular MacBook Pros. You should take this into consideration when making a purchase.
For me personally its a tough choice, but in the end I would probably go with a fully-optioned traditional MacBook Pro. I work a lot with Photoshop and build up many hundreds of gigs of files every year, so for my personal situation this is a big issue. For you it may be different.
