chartConstructor
chartConstructor
Post by Info-Mac » May 27th, 2002, 9:00 am
Download: http://archive.info-mac.org/app/chart-c ... or-101.hqx
ChartConstructor is a program used to create Gantt and PERT charts. Once
created these charts can be printed or exported as image files for
inclusion in other documents, or on the web.
System requirements: ChartConstructor should work on any computer
running Mac OS 10.1 or later.
ChartConstructor is shareware, a single user license costs US$30.
Web: http://www.headshack.com
Email: stuff@headshack.com
Changes in this version
* French Localization
* Ability to rearrange tasks in Gantt charts added
* Dependent entries in PERT charts now update their dates the same as
entries in Gantt charts
* All the information that could be recorded for entries in Gantt charts
can be recorded for PERT entries
* PERT entries can now display a longer task string
* Connecting points for arrows in PERT charts are now spread out
* Cursor now changes to an arrow while making connection
* Pressing the delete key with a chart entry selected will now delete it
* Fixed a display glitch that caused connections to be drawn on the
window under certain situations
*Improvements to the manual
