Download: http://archive.info-mac.org/app/floatin ... -13-jp.hqx
This is the Japanese version of the FloatingNotes package.
4 Cows at Tucows!
What's the point of having notes if they're buried by other application
windows and you can't see them? Sure, Stickies is free, but
FloatingNotes "floats" on top of all other application windows so you
can always see them. FloatingNotes uses no system extension, and best of
all, FloatingNotes is a Carbon application so it works under OS X as
well!
FloatingNotes automatically saves all open notes when you quit. To
delete a note, simply close the window.
FloatingNotes requires OS X, or OS 8.5 or 9 and CarbonLib 1.3 or later.
CarbonLib is free and can be obtained from your "Software Update"
control panel.
Changes:
*Note window transparency can be set in the preferences (Mac OS X only).
