AlarmTimer1.0.dmg.hqx
Post by Info-Mac » October 21st, 2004, 9:00 am
Download: http://archive.info-mac.org/app/time/alarm-timer-10.hqx
Alarm Timer is a useful repeating timer, and simple alarm clock. Use it
as a reminder to get up and take rest, time your egg, an exercise timer
or even run an AppleScript(R) after the time is up. What makes Alarm
Timer different is that you can have it signal to you continuously,
without the need to constantly close dialog boxes. For an alert sound
you can choose any sound located on your computer, even an AAC file or
MP3 file. Alarm Timer also serves as a simple alarm clock.
Features
¥ simple and easy-to-use interface
¥ alert you via a sound, dialog box or window 'flash'
¥ run an AppleScript¨ after the time is up, once or repeatedly
¥ choose your own sound, including AAC or MP3, to signal or alarm you
¥ set your signal or alarm message easily and intuitively
¥ clock window can be virtually any size
¥ have the timer/alarm run only from your dock, including a dock menu
¥ your feature request here!
Requires: Mac OS X 10.2 or higher
Alarm Timer is $5USD shareware. You can use Alarm Timer as much as you
wish, but after the 14-day evaluation period you'll be periodically
notified of it's unregistered status.
Contact Information
Web Site: http://www.siddha.ca/software/
Order Online: Paypal: http://www.siddha.ca/software/17/alarm-timer
Product Support: http://www.siddha.ca/software/17/alarm-timer
Support and Feedback: michaelkhanna@gmail.com
