Download: http://archive.info-mac.org/app/time/ti ... 02-osx.hqx
Combines a punch clock, invoice generator, and time sheet generator in
one simple application. Track time billed to any number of clients and
projects, and automatically create customizable reports, invoices, and
time sheets. A relational database ties it all together, and all of
the underlying data may be edited by the user, making it easy to fix
missed punches. Invoices and time sheets may be printed and emailed
directly from the program.
Invoices are fully customizable, may feature your company's logo, and
can be created from scratch if you wish to track your time using some
other method or just from your head. Data may also be exported for use
in other applications or spreadsheets.
A comprehensive, inexpensive solution for contractors, consultants,
freelancers, or anybody who needs to track time spent at the computer
and bill for it. Includes online help and documentation.
This version is for MacOS X only. Visit
http://www.the-computing-edge.com/ for cross-platform versions and
more product information.
Shareware, $15 registration fee. Fully functional for 30 days;
invoice generation will be disabled if unregistered after 30 days.
