BinHqx 1.02
BinHqx 1.02
Download: http://archive.info-mac.org/cmp/binhqx-102.hqx
This looks like a good solution if one needs a small binhex conversion
util.
----------------------------Original message----------------------------
Hello,
Enclosed below is Howard Fukuda's excellent Desk Accessory
"BinHqx 1.02 DA'. Shareware $5. It dates 1990, but works
very fine with System 7. Handles both Encoding/Decoding BinHex,
plus, 'Join&Decode' and 'Segment' features.
By setting the 'I/O buffer size' to the maximum, it operates
VERY quickly. Works twice/threetimes faster than StuffIt's
translator!
Hope you enjoy it:
> After downloading some files from the um-mts.cc.umich.edu archives, I
> found that BinHqx 1.01 has problems when spaces are inserted in the middle
> of archives. This seems to happen occasionally after a line-feed. 1.02
> corrects that problem.
> BinHqx is a Desk Accessory that does BinHex 4.0 translation in addition to
> file joining/splitting. Major advantages are convenience and speed, but it
> is ShareWare. Please register your copy.
