[*] Review of eDisk and TimesTwo
Download: http://archive.info-mac.org/cmp/downer.hqx
Downer.sit.hqx sould go in the /info-mac/util directory.
Downer is a useful utillity that will automatticly turn off your computer
after a set number of idle seconds. Downer alows you to use "dont shutdown
points" Where if the mouse is in that location the computer will not shutdown.
This is a review of the only two driver-level compression programs
currently available. It also addresses a number of other compression
related issues. I'll update this document when new information or new
product in this category (such as Stacker for Macintosh) becomes available.
I welcome any comment or suggestion, and espeicially your experience with
these products.
To the Moderators: please replace the file times-two.txt that I previous
submitted with this one.
Tony Huang
A little more than six months ago, Golden Triangle introduced TimesTwo, the
