MacBinaryOSAX 1.0
MacBinaryOSAX 1.0
Download: http://archive.info-mac.org/cmp/mac-binary-osax-10.hqx
MacBinaryOSAX 1.0
written by Sean Hummel
Ever notice that when you look around for 'C' code which encodes/decodes
MacBinary III files. It's hard to find, and certainly it's harder to have to
make it fit into your code. This code is completely free, and may be used
for any purpose.
The OSAX is a simple interface which enables the code to be used via
Applescript. I use it so that I won't have to install Stuffit? from Alladin
on each of my work machines. This also makes scripts easier to write, as
there aren't ever any problems locating StuffIt.
The project file is a CodeWarrior Pro 5 project, so you for those that are
using CWPro4 or earlier, you'll need to create a project.
