Stuff and Hex 1.0
Stuff and Hex 1.0
Download: http://archive.info-mac.org/cmp/stuff-and-hex-10.hqx
This application REQUIRES the Stuffit Engine=AA which is part of the Stuffi=
t
Deluxe=AA Stuffit SpaceSaver=AA and SITcomm=AA packages.=20
This application is just a quick (15 minute) hack that I did for my own
use and then cleaned up a little for distribution. The purpose of the
application is to first comress and then binhex files for electronic
distribution. It is intended to be used as a drag and drop application.=20
You can use it to choose files, but not folders, from the 'File' menu.
After I had written this it turned out that Drop=A5Stuff (also part of
Stuffit Deluxe=AA package) also does this (I always use Magic Menu rather
than Drop=A5Stuff). I decided to go ahead and distribute it because lots o=
f
people have the Stuffit Engine as part of Stuffit SpaceSaver=AA and
SITcomm=AA, but don't have Drop=A5Stuff.=20
Chris Owen
