AppSwitcher Config AS
Download: http://archive.info-mac.org/cfg/app-switcher-config.hqx
AppSwitcher Config is a simple little AppleScript that lets you configure OS 8.5's application switcher (the little thing that you get when you tear-off the applications menu). It lets you set the following, most of which is otherwise impossible without some knowledge of AppleScript:
* Orientation (horizontal or vertical)
* Growth direction (top-left corner or bottom-right)
* Ordering (launch order vs. alphabetical)
* Icon size
* Visibility of the frame
* Keyboard switching properties
Douglas Anderson ([email protected])
finger: [email protected]
http://www-cs-students.stanford.edu/~dianders/
