DPC Bundle 1.1.2 - A Desktop Picture Changer
Download: http://archive.info-mac.org/cfg/dpc-bundle-112.hqx
DPC Bundle is yet another set of tools that let you automate the changing
of your desktop picture. Among tools included is an AppleScript and an
application:
- Desktop Picture Changer: Changes the desktop picture from pictures in a
folder. It can choose them randomly or sequentially. It can change the
desktop at specified intervals or just when you run the applet.
- Desktop Picture Aligner: A great little tool that lets you set default
alignment settings for any picture to be displayed on the desktop. For
example, you can specify a picture to be displayed scaled and aligned to
the bottom right corner of the screen.
Changes in 1.1.2:
- Fixed a small bug in Desktop Picture Aligner that prevented it from
properly setting the creator type of multiple files at once.
Try it out. At the very least, you'll find Desktop Picture Aligner useful.
It doesn't need the rest of the tools. Requires Mac OS 8. It's freeware,
enjoy.
Sarwat Khan, [email protected]
http://www.interlog.com/~sarwat/
Check out Sarwat's Mac stuff (including the DPC Bundle):
http://www.interlog.com/~sarwat/mac/mac.html
Check out Painting (shareware):
http://www.interlog.com/~sarwat/painting/
