PowerBook Essential Strip 1.0
Download: http://archive.info-mac.org/cfg/essenti ... -strip.hqx
Essential PowerBook Strip is a control strip module that displays detailed
information about your PowerBook's battery. The information it gives you
will help you determine, with precision, the state of your battery and how
much battery power you have left. It also replaces Apple's "HD Spin Down"
module and Apple's "Sleep Now" module.
Jason Place
