ExtractIt! for System 2.0 - The simple, powerful diagnostic
Download: http://archive.info-mac.org/cfg/extract ... system.hqx
ExtractIt! for System 2.0 is a very small and versatile application which will
return a truckload of information on your computer. It takes up a mere 250K
of disk space and can run on virtually every computer system, but it returns
enough information on your computer to be a great assistance in any situation.
All of this information is formatted in 32 easy-to-read, tabulated screens
sorted into 4 menus, making it easy to quickly hone down the problem. All
170+ different categories of data are outlined in such a way that it doesn't
confuse even the most novice of Mac users. There's a list of 100's of bugs
and if they've been fixed, a custom Gestalt selector viewer with a visual
interface, and even a built-in on-site mini-manual!
Best of all, this program requires virtually nothing to run:
- 68K or Power Macintosh, any speed
- 9" monitor
- 250K of disk space, 500K of RAM
- ATM-compliant ITC Times & Helvetica fonts (included)
...and that's it! All this for only $8, too! ExtractIt! for System is sure
to be a valuable addition to any Mac user's cornucopia of software programs.
Download it already!
Tim Morgan
Lightning Bolt Software
http://www.haxor.com/~lbsupport
