FolderWatcher 1.1
FolderWatcher 1.1
Download: http://archive.info-mac.org/cfg/folder- ... folder.hqx
FolderWatcher is an application designed to help you keep track of the
size of various
folders on a given volume. You can set a specified amount of authorized
space on a
per-account basis; FolderWatcher will alert you only if that amount has
been surpassed.
A dated text file with a list of "oversized" folders is created.
FolderWatcher will perform its task automatically upon startup and then
quit (the
"autocheck" feature).
IMPORTANT: If you want FolderWatcher to run without doing anything (for
data
entry, etc.) hold the option key down as the program starts up.
You must do this the first time the program is run, otherwise it will
have nothing to
check, and will quit immediately.
On-line help is available from within the program.
Persons who might find this program useful are those who maintain
computers in
schools, web servers, etc.
FolderWatcher is free.
Requires:
System 7 or newer
68040, PPC or "G3" processor
4 MB RAM (for most models)
For further information, contact the author at:
