MacAT v3.1 released. Cron for Macintosh
Download: http://archive.info-mac.org/cfg/mac-at-31.hqx
MacAT v3.1 now adds "Compress File, "Compress Folder" and "Uncompress File" tasks as well as fixing a nasty bug with the "Put Away" task.
MacAT is a Windows AT/UNIX cron task scheduling application for Macintosh server administrators. It is a fat binary application that allows 17 of the most common MacOS tasks to be run daily, weekly, monthly or yearly without user intervention.
These scheduled tasks include:
Launching Applications, Files and AppleScripts; Quitting individual applications or alternatively quitting all currently running processes; Rename and Delete any File or Folder; Mount remote AppleShare volumes; Copy Files or Folders to mounted AppleTalk volumes; Unmount nominated AppleShare volumes; Restart or shutdown the Macintosh, and sending eMail.
$39 Shareware from MacSOS, Australia
http://www.garvan.unsw.edu.au/gerham/macsos/
