Mac OS 8.5 Patchers 1.0
Download: http://archive.info-mac.org/cfg/macos-8 ... ers-10.hqx
Mac OS 8.5 Patchers
by Grant Neufeld
Freeware
Version 1.0 - Tuesday, November 3, 1998
URL:
Download:
The Mac OS 8.5 Patchers includes separate patcher applications for
improving/fixing certain interface components of Apple's Mac OS 8.5. This
includes making the "Sherlock" search windows properly resizable with a
zoom box and size box, and fixing the "Flash Icon"/"Display Dialog"
checkbox bug in the "Internet" control panel interface.
The package also includes a few Sherlock internet search plug-ins.
(available separately from )
No technical support is available for this product. Bugs may be reported to
[email protected].
