App Store Category Problem
kyawthura251
Post by kyawthura251 »
I am using 3G iPhone. I couldn't access Categories in App Store , but all the rest Featured , Top25, Search,Updated are Ok. Colud some one help me ? I have no idea. :(
Re: App Store Category Problem
kyawthura251 wrote:I am using 3G iPhone. I couldn't access Categories in App Store , but all the rest Featured , Top25, Search,Updated are Ok. Colud some one help me ? I have no idea. :(
Have you tried fully restarting your phone?
kyawthura251
I have tried restart , reset setting and also restore from iTunes . But I still couldn't access categories :(
ah_pat
Post by ah_pat »
Yeah, i got the same problem here.
After my upgrading of OS in my iPhone, i got this problem.
It was not so previously.
Can anyone help ?
Are either of your phones jailbroken? Or maybe there is something going wrong with iPhones in Singapore?
kyawthura251
Mine is not jailbreak. App Store problem is not me only ( also not Singapore only) . I have seen at Apple web community ,a lot of people got the same problem like me from all over the world. May be Apple server problem!
I only suggested because the only two people who have reported it here at Info-Mac have both been from Singapore, which represents an unusually high influx of Singaporeans around these parts. That being said, this particular user sees Categories just fine.
kyawthura251
Thanks for your suggestion , Turboladdade. :D
ah_pat
Post by ah_pat »
kyawthura251: What is the version of your iPhone OS ?
kyawthura251
Mine is 3.1.3
chasm
128 MB
Post by chasm »
I'm using a jailbroken/unlocked iPhone with 3.1.2 and having no problems with "Categories" on the App Store.
Cheers
chas_m
http://spacejavelin.com
chasm wrote:I'm using a jailbroken/unlocked iPhone with 3.1.2 and having no problems with "Categories" on the App Store.
But not in Singapore :D all my categories are showing up fine too.
kyawthura251
Yahuu.....categories is fine today as usual :D
thanks everybody for suggestions
Was there anything you did to get it working? Or did it just start working all by itself?
kyawthura251
Yeap , it is fine again by itself . And I need to agreed again for terms and condition iTunes store. :)
Oh, actually, that might have been what was causing your problems. You need to re-agree to those terms from time to time as Apple updates and modifies them. I believe this most recent one was in preparation of iPad-specific features.
kyawthura251
Humm...I hope so.May be Apple is doing something update for iPad :)
Lblessens
Post by Lblessens »
Hi! I'm a newby & just wondering what "Jailbroken" means? Also I'm experiencing a constant APPLE request for my password. It's really getting annoying! I turned phone off several times hoping to make corrections. Now even entering some of my apps this pops up again? Any ideas? I need to report the problem. Not sure How to get the help. Went to apple site & techs wanted 2 help for price$! I payed for warranty. Any help here much appreciated! Blessens To U All! TU Ahead Of Time!!!
Jailbreaking is a method of hacking your iPhone. It is frowned upon by Apple. Your iPhone is probably asking for an iTunes password to update your apps. Apps are updated quite frequently by their developers and your iPhone will ask for a password every time an app needs an update.
Is that what you're seeing?
Lblessens
Post by Lblessens »
TU! Yes! And the question about Jailbreaking is present here only because in a couple other folders in here the term was used. I was just wondering. I bought my iPhone directly from Apple. The enter password is still popping up. I think you already helped me by letting me know to sync my iPhone off my brothers desktop could be my issue here! TU AGAIN! Most Gratefull! Blessens...
