Included File is a new version of QuitMenu for Finder.
It is made for Finder 8 or 8.1.
It adds a QuitMenu under the Special Drop down Menu
and several Command keys for Empty Trash etc.
It needs ResEdit and Instructions are included.
The file has been checked with SAM 4.5 and is
constructed by FMR.
