RecCleaner10.hqx
RecCleaner10.hqx
Download: http://archive.info-mac.org/cfg/recent-cleanup-10.hqx
Announcing the release of "Recent Cleanup 1.0".
Do you like Apple's Recent Applications menu, but find that installers and other
items make it difficult to find what you are looking for? Recent Cleanup is a
control Panel that allows you to remove items from the Recent Applications menu
that match certain keywords you define. For example, to remove installer
applications, simply enter the keyword "install" in the control panel (you may
define as many keywords as you wish). All entries in the Recent Applications menu
that contain the word "install" will be removed at startup, or when you press the
command-option-c (the hot key sequence).
System requirements: * System 7.5 or alter
For more information, please read the Read Me file enclosed, or visit our Web
page:
http://www.creality.com/rc.html Thanks,
Robert Chancellor Crystal Reality Software http://www.creality.com/
