Sigerson 1.0
Sigerson 1.0
Download: http://archive.info-mac.org/cfg/sigerson-10.hqx
Sigerson is the only sets manager for Sherlock that actually selects the
sites in Sherlock. It doesn't move the sets around on your disk, so it's
reliable, fast, and all your sites will be always be available from
Sherlock, even if you dont run Sigerson first. You can also create a
Sherlock saved search document right from Sigerson. Version 1.0 is
available on my web site at:
http://www.wwa.com/~sentman/sigerson
And it's FREE!
Requirements: MacOS 8.5 and Sherlock, PPC only.
Please feel free to include this on any CD-ROM compilation disk.
-James Sentman
