Startup Screen Randomizer.hqx - Randomly Chooses StartupScreens
Download: http://archive.info-mac.org/cfg/startup ... omizer.hqx
This program will randomly choose a picture file in a folder you choose and
set it as your startupscreen It has the optional settings of being able
scale the image and to print a text message across it.
