SwitcherSetter 1.0
SwitcherSetter 1.0
Download: http://archive.info-mac.org/cfg/switcher-setter.hqx
Included with Mac OS 8.5 is a wonderful feature called the Application
Switcher -- a configurable palette that shows your currently running
applications.
Apple enabled the Application Switcher with a ton of different options
but no easy way for the user to set them. That's where SwitcherSetter
comes in (or if you're from Boston, "SwichaSetta").
SwitcherSetter offers an easy-to-use interface to modify all of the
different Application Switcher options and settings. SwitcherSetter is
fully PowerPC-native and Mac OS 8.5-savvy, including Theme support and
even Balloon Help!
Be sure to check out the SwitcherSetter web site at
SwitcherSetter is freeware, actually more specifically, it's beerware. If
you ever run into me at a bar in the Boston area and want to buy me a
beer, I won't turn you down.
