INFO-MAC Digest V2 #13
Subject: INFO-MAC Digest V2 #13
Date: Wed, 13-Mar-85 22:05:41 EST
Article-I.D.: uw-beave.912
Posted: Wed Mar 13 22:05:41 1985
Date-Received: Fri, 15-Mar-85 00:47:06 EST
Lines: 311
INFO-MAC Digest Wednesday, 13 Mar 1985 Volume 2 : Issue 13
Skeleton Mac application
SKEL source
MacAdvantage
Possible bug in Extras V1.2
XLISP article
MIDI
MIDI again
Reading Lisa disks
Date: 06 Mar 85 12:47
Subject: Skeleton Mac application
For about 9 months I have been using a skeleton Lisa Pascal program
called SKEL to teach people how to write Macintosh applications. The
aim of the program is to do very little (events, menus, a window with
dragging and growing, desk accessories, modal dialog box, icons) but
to do it well and cleanly, in a way that remains correct in larger
programs.
SKEL contains directions for self-study. It is easily digested,
being rather short. It can be compiled under Workshop 2.0 or 3.0.
You are welcome to use and abuse SKEL, so long as that use is not
for commercial purposes. I would appreciate it if significant
revisions were sent back to me for incorporation.
I am posting to net.sources on USENET the source code SKEL, [
stored in UTILITY-SKEL.PAS ] the resource definition file SKELR, [
stored in UTILITY-SKEL.RESDEF ] and the Lisa EXEC file SKELX, [ stored
in UTILITY-SKEL.EXEC -jma ] which will perform all necessary steps to
produce on running program on an inserted floppy. Steve Maker
USPS: Academic Computing, Dartmouth College, Hanover NH 03755
USENET: {linus|decvax|cornell|astrovax}!dartvax!maker
ARPA: maker%dartmouth@csnet-relay
CSNET: maker@dartmouth
Date: 06 Mar 85 12:48
Subject: SKEL source
[ I have included the program header since its's so informative. As
mentioned
the full code resides in UTILITY-SKEL.PAS -jma ]
{%describe 'a Skeleton demo program'} {$X-} {Turn automatic run-time
stack expansion off - it's a Lisa concept.} {$R-} {Turn off range
checking; it can cause crashes.} PROGRAM Skel; { By Steve Maker
Academic Computing
Kiewit Computation Center
Dartmouth College
July 14, 1984 Copyright notice:
SKEL may be copied and used by anyone, so long as that use
is not for commercial purposes. Please send significant
changes
back to me so that I may incorporate them into future
versions. Why SKEL?
Skel is a skeleton demo program. Its purpose is to
illustrate
in a clear fashion, isolated from any particular
application,
the basic code for handling a simple Macintosh user
interface.
It strives to be correct as far as it goes, without many
short-cuts
that would lead to trouble in larger applications.
I think of SKEL as a program that does nothing, but does it
well. What does SKEL do?
It handles:
Events, carefully handling only those which are its
business, and passing the others on to their
respective handlers.
A Window, which is filled with Dark Gray, and can be
activated or inactivated, updated, dragged
and grown but NOT scrolled or closed.
Menus, including the Apple Menu. An "About Skel" menu
entry
is provided. A File menu offers Rattle and
Frighten,
which just invoke dialog boxes, and Quit.
Command
key equivalents are supported.
The Desk Accessories, supported in the Apple menu,
and correctly meshed with the other features.
NOT supported are Undo, Cut, Copy, Paste and
Clear
(and keyboard equivalents) for desk
accessories.
A Modal Dialog Box, used to communicate with the user.
Special icons for the application and its related
files.
The Finder information (in the resource file).
In accordance with Macintosh guidelines, everything
possible is
kept in the resource file: window description, menus,
dialog specification, and the "About Skel" and other
strings.
In addition, the resource file handles the Bundle, File
References,
and Icons that determine what Skel's icon looks like, and
other
information for the Finder. How do I use SKEL?
Study it. Modify it to test your knowledge. Steal working
pieces of code for your own programs. Beat on it. Subject
it to cruel and unusual experiments. Pay heed to its
warnings. What do I study first in SKEL?
Initially you should ignore several sections of SKEL, and
the calls
made to them. I recommend X-ing them out in your listing.
The sections to ignore on the first round of study are:
Report: ignore the implementation
SetUpMemory: ignore all of it
DrawWindow: ignore the scroll bar and grow icon
handling
ReSize: ignore all of it
DoCommand: ignore the Desk Accessory handling in the
Apple Menu
MainEventLoop:
MouseDown handling: ignore inSysWindow, inDrag,
inGrow
keyDown, autoKey handling: ignore this.
In the resource definition file, SKELR:
Finder information (offset by asterisks):
ignore this whole section, icons and all. What
should I read in Inside Macintosh?
You should read the following sections of Inside Macintosh,
in the order given. At first, just lightly skim the
sections
with parenthesized names. Read the others in some depth.
Read
the starred (*) ones in great detail. Eventually, you will
have
read all sections thoroughly, and many many times, I
promise you.
To start:
* Inside Macintosh: A Road Map
(User Interface Guidelines)
Structure of a Macintosh Application
* Putting Together a Macintosh Application
Then, (low-level sections are listed first):
* Memory Mgr Intro
(Memory Mgr)
* Resource Mgr (through "Using the Resource Mgr")
* QuickDraw
(Desk Mgr)
* Event Mgr (through "Event Mgr routines")
Window Mgr
Menu Mgr
(Dialog Mgr)
How do I get SKEL to run?
The best way is to use the special EXEC file SKELX, and
insert a
Macintosh diskette into your Lisa. SKELX will write on it
with
MacCom, and will set all info correctly so that the icon
will appear.
You may also use Apple's EXEC file, or the Dartmouth exec
files
T/EXEC or M/MACCOM. The first two will not set the icon
correctly,
while M/MACCOM will do that right, and also refrain from
recompiling or repeating other steps if they are
unnecessary.
Date: Sun, 10 Mar 85 06:42:49 PST
Subject: MacAdvantage
Steve -
I've been using MacAdvantage heavily for about 2-3 months. It's
actually a very nice system to use. I've converted my Go program to
it (see Nov '84 BYTE) and have added a number of bells and whistles.
I've also written a 3-D star map program with it, which will show up
in the July issue of BYTE. The compiler is fast (compared the the
oh-so-slow multi-pass MacModula-2 compiler) and the development
environment (editor, executive, resource maker, etc.) is complete.
I only have one major complaint with MacAdvantage: its speed. I
modified my Go program to let the computer play against you, but it
takes far too much time to make even simple, stupid moves. My best
guess is that it is about 10x slower than the various C compilers out
for the Mac. However, it does make a good prototyping language; I
suspect that I could convert my working programs to Lisa Pascal in
very short order.
..bruce..
Bruce Webster/BYTE Magazine
bang!crash!bwebster@nosc
{ihnp4,
sdcsvax!bang}!crash!bwebster
Date: Thu, 7 Mar 85 16:35:27 est
Subject: Possible bug in Extras V1.2
..."Extras" was posted to USENET's net.micro.mac some time ago.
[- EXTRAS.HCX has been in info-mac since Feb. -jma ]
Anyway, Extras is a desk accessory which allows you to show free
disk space, delete files, show free memory, and compact memory, all
from within an application. It's being distributed on the "freeware"
system (i.e., "if you like it, please send the author (Bob Luce)
$X.00...").
I've encountered what appears to be a bug in version 1.2 of the
Extras desk accessory. I had installed Extras on a MacWrite disk, on
which MacWrite happened to be the startup application. I was able to
open and use the DA from within MacWrite, but attempting to close it
caused a system error with ID=02. One noticeably odd thing about this
error was that for the first time I've seen, the "Resume" button
actually worked! Clicking it brought up the Save dialog box, allowing
me to save my document, and then exited to the Finder.
I also found a couple other oddities. With MacWrite still the
startup application, I rebooted, then quit MacWrite, and then launched
it again. The Extras desk accessory then worked normally, and could
be closed without causing a crash. The same was true when there was
no startup application (i.e., the startup application was the Finder).
I also tried setting MacPaint as the startup application; this again
caused Extras to crash when closed (though this time there was no
Resume option--is that some sort of MacWrite "feature"?)
All this seems to indicate that you cannot close Extras without
having previously loaded the Finder. Anyone out there had a similar
experience, or have an explanation?
Date: Mon, 11 Mar 85 22:47:17 EST
Subject: XLISP article
There's a good article by David Betz about XLISP in this month's Byte.
Date: Sun, 10 Mar 85 08:41:59 pst
Subject: MIDI again
The previous message about MIDI and time constants was not
quite correct. First, MIDI's baud rate is 32000 (31.25K), not 31250.
Second thee formula for calculating the time constant was missing
several variables. The real equation is:
tc = (clock / (2*baud_rate)) - 2
However, the "clock" variable is divided by a clock rate constant,
which can be 1, 16, 32, or 64. The Mac uses a clock factor of 16. So
the real Mac serial clock rate is 368400 (115200*2*16).
If you change the clock factor to 1, and reapply the formula, you get
a time constant of 76. This translatestrue baud rate of 31779 baud,
which is within 0.69% of the desired MIDI baud rate, well within the
MIDI spec.
I have already built a MIDI box which translates MIDI signals
into RS422 signals. I am working on a driver. The hardware box only
cost me $20, including a case (and at Radio Shack, no less!).
More on this when I have something working...
Andrew Shebanow
using (shebanow@ucbernie) (my brother's account)
Date: Sun, 10 Mar 85 09:16:37 pst
Subject: MIDI
I just want to make sure that my last note was correct. I may
have misremembered. The correct "time-constant" value should be 56,
not 76 (which is what I think I wrote. If you could you could also
tell people that I can be reached at (415) 769-5445 during work hours
(weekdays, 9-6).
Thanks... Andrew G. Shebanow
Date: 9 March 1985 00:12-EST
Subject: Reading Lisa disks
Does anyone know of a program to read Lisa disks on the Mac? It would
be nice to have access to some of the software supplement assembler
include files, etc.
-Michael
