View 8-er 1.3
View 8-er 1.3
Download: http://archive.info-mac.org/cfg/v8-prev.hqx
View 8-er is a set of plug-ins for Tiger Tech's Window Monkey control
panel. When used with Window Monkey, View 8-er provides your
"list-viewed" Finder windows with a "white-on-gray" lined display, which
not only makes your Mac look like it's running Mac OS 8, but makes
"list-viewed" windows tremendously easier to read.
Version 1.3 of View 8-er adds support for the Geneva 10 font (the Mac OS
8 default), and remembers to include the "Register" application (OOPS!)>
Purchase of View 8-er for $5 removes all "$"s, and entitles purchasers to
ALL future updates.
Sincerely,
Mark Fiske
Fake-8 Technologies.
